show ur different CB mounting spots
Old 12-25-2009, 08:03 AM
mattyhfd's Avatar
Default show ur different CB mounting spots
where did u mount ur CB radio? show a pic
Old 12-26-2009, 07:00 AM
donnie's Avatar
Location: Simi Valley, Ca., Taylorsville, Ut. and places in between
This is where I mounted the antenna and the Cobra for now.
Thinking about relocating the radio soon.
Hope this helps.
Name:	Rad Install 003.jpg
ID:	34527   Click image for larger version
Name:	Antenna Pics 005.jpg
Old 12-26-2009, 07:50 AM
The_Yeti's Avatar
Home made mount across roll bars.
The antenna is mounted behind the spare using an antenna mount from arizona rocky road.
Old 12-26-2009, 08:59 AM
Suffolk JK's Avatar
Old 12-26-2009, 08:33 PM
sburggsx's Avatar
I thought it would suck here, but honestly I don't notice it at all. Your leg doesn't bend in a way you can even touch it and still be using the gas pedal. No holes drilled, used an existing screw through the provided mounting bracket. This was a temp mount for a trip that I was going to take out and replace with a 75 like everyone else. Sadly, I like this enough I might have to do some work on the power wires.
Old 12-26-2009, 08:59 PM
09jaykay's Avatar
im thinking about putting my under my seat, has anyone done this
Old 12-27-2009, 04:05 AM
BIG_Steve's Avatar
put mine at rear of console. can still hear it good and clear, and i leave the mic on the pass seat most of the time so i am not alwaws bending back to get it.
Name:	100_0441 (Small).JPG
Old 12-27-2009, 05:56 AM
Suffolk JK's Avatar
If for some reason you submerge the JK, water will get in, and destroy the CB.
Old 12-27-2009, 07:16 AM
Viper64's Avatar
I have a magnetic antenna lying around, I'm wondering where I should put it on the truck.
Old 12-27-2009, 09:18 AM
donnie's Avatar
At different times Iv had a mag mount cb and ham antenna on the Jeep.
I had them on the right side by the windsheild and they seemed to work good there.
Quick Reply: show ur different CB mounting spots
