Annoyed with lights
Old 04-19-2014, 09:09 PM
headrock's Avatar
Default Annoyed with lights
I installed hella vision plus and the kc h4 conversion pigtails. The bulb on the passenger side went out and I pulled the bulb, it was fine. Installed +30 bulbs on both sides about a month ago. The passenger side went night night again tonight. The bulb is fine, again. Not sure what's up. Driver side has been fine. Any ideas?
Old 04-20-2014, 06:03 AM
Jersey_Devil's Avatar
That's what my hids did, I would have thought that was only an hid problem.... Ur hellas are halogen right? Maybe a bad conversion harness? Just a thought. And did u try to switch ur driver and passenger lamps to see if the problem goes to the other side? If it does u know its that physical lamp that's bad
Sent from my obama monitoring device
Old 04-20-2014, 06:08 AM
Jeepstin12's Avatar
I installed the highest capacity halogen in my Volvo and the heat from the draw literally melted my wire harnesses. Check your wires, make sure there is no damage.
Old 04-20-2014, 10:24 PM
headrock's Avatar
Going to dig in there on Wednesday and check the harness and then flip flop the lights. I will post an update as soon as I am done. Thanks for the info!
Old 04-21-2014, 07:05 PM
Macman1138's Avatar
Get yourself some Truck Lites. Bright, long lasting no hassles.
Old 04-21-2014, 07:12 PM
Tooadvanced's Avatar
^^^^^^^this
Quick Reply: Annoyed with lights
