Help wiring new 10" LED Light Bar
I picked up one of the knockoff rigid 10" light bars off of ebay and I'm trying to figure out how to wire the dam thing up.
It only has 2 wires coming out of it, a blue and a brown.
I'll be wiring it into my OTRATTW switch. I'm guessing I need a fuse and a relay in there somewhere? My google skills have failed me in finding a nice drawn up diagram on how other people have wired this thing. Help!
according to the spec sheet
20 x 3w LED
3.1A Amp Draw 12V
https://www.jk-forum.com/forums/jk-e...source-191552/
Pick up the supplies you need from your local automotive shop:
#16 awg wire ( get a rough measurement on how much to buy, always buy a little more than you think ).
Fuse Tap
4 amp or 5 amp fuse to fit fuse tap.
#16 awg insulated butt splice wire fittings ( about 6 or so )
#16 awg female spade wire fittings ( about 6 or so ) used to connect wires to the switch.
Wire loom
Wire ties
Electrical Tape
Install the fuse tap per Ron's post.
Using a "butt splice", splice on a wire to the tap.
Run this wire to the switch.
Using a "female spade connector", connect the wire to the common side of the switch.
Using a second "Female spade connector", connect a new wire to the secondary side of the switch.
Run this new wire to the light bar.
Temporaraily connect this wire to one of the wires connected to the light bar.
Temporaraily connect the second wire from the light bar to ground.
Install the fuse and test the light.
If the light doesn't work, reverse the temporary connections and try again ( one way should work ).
Make all the connections permanent.
Cover the wires with loom.
Wrap a piece of tape around the loom in different spots to secure the wire inside.
Tye the loom in place.
Hope this helps.
Thanks for the help!
Got it mounted and all wired up!
I'll take some pics with all 3 sets of my lights tonight. Regular headlights, rigids on the a pillar and the ebay rigidlike 10" bar
