JK Headlights not getting enough voltage
Not sure on that. The way to test the presence of the pulse is like one of the others posted.
Key On / Engine Off - should be full 12V
Key On / Engine On - if pulse then you'll get a low voltage on your meter / if not pulse then you'll get a full 12V
The 2008 service manual says the TIPM sends PWM voltage to the headlights. When it describes the fog lights, it say the TIPM sends battery voltage to the fog lights.
Guess I'll have to go out and put a duty cycle meter on the fog light wires.
I've read countless threads on people having issues when replacing the fogs. I think the meter will show that they are PWM. Search "fog flickering".
Problem solved
Problem solved!
When the Jeep was off, the LED lights worked fine. As soon as I turned the Jeep on, they flashed a couple of times, then went out. It seemed like the PWM was detecting if there was a light on the end, didn't detect one and then shut off and turned power off to the line.
I added resistors to each headlight harness to 'trick' it into thinking there was a bulb on the end instead of the LEDs. Now, when I turn the Jeep on they no longer flash. In addition, they have stayed on ever since without flickering or anything. Seems like problem solved. Only problem, those resistors are really *$%&_* hot. I need to find a place to mount them so they don't melt anything under the hood.
Problem solved!
Good deal. So that's a drawback of that SMS box perhaps. The harness I use plugs into one of the H13 headlamp plugs and sends that signal to the capacitors and then to the relays which activate the circuit that ties into the H4 plugs and uses power from the battery (with a fuse) directly.
Did you build your harness yourself or buy it? If you bought it, can you send me a link to what you used?
Actually....this is bypassing that SMS box altogether. I think I may just take that box out actually since its working without it. No need to risk screwing things up again.
I built my harness. I use a Bussman fuse panel to run my fuses and relays. The only items not in the Bussman is the diodes and capacitor I used to get the flicker out.
