led tail lights, something different
Old 09-28-2014, 05:45 PM
Baddkarmaracing's Avatar
Default led tail lights, something different
I have always liked the look of the round trailer style tail lights that most people use on jeeps with rear armor, but i have no interest or funds for armor at the moment so i have been thinking about doing some thing similar myself but never could come up with a good way to do it and not look bad, then i found these http://www.rockridge4wd.com/ROCKRIDG...-p/rr-5002.htm, i like most of this idea, but im not too fond of the little led reverse light. so now the search is on for some different parts to use, i havent decided what tail lights i am using or what reverse lights but i am open to ideas if anyone has any. pics are coming as i gather parts.
Old 09-30-2014, 07:34 AM
bombout800's Avatar
Check out the oro dot lights. Look better and the shroud they are in goes right into the factory designed spot
Old 09-30-2014, 09:19 AM
doesn't look like they go in the factory spot at all, maybe on the older jeeps but these are supposed to work with aftermarket armor which I have no use for at the moment
Old 09-30-2014, 11:41 PM
Former Vendor
Offroad_Elements's Avatar
This one is for JK application
http://www.offroadelements.com/oro-l...ngler-jk-2007/
Old 10-01-2014, 12:16 AM
RedRockJeeper's Avatar
I have always liked the look of the round trailer style tail lights that most people use on jeeps with rear armor, but i have no interest or funds for armor at the moment so i have been thinking about doing some thing similar myself but never could come up with a good way to do it and not look bad, then i found these ROCKRIDGE 4WD LED Tail Light Conversion KIT - FLUSH MOUNT 4" ROUND W/ RED LENSE - For Jeep Wrangler JK 2007-2013 2 & 4 Door, i like most of this idea, but im not too fond of the little led reverse light. so now the search is on for some different parts to use, i havent decided what tail lights i am using or what reverse lights but i am open to ideas if anyone has any. pics are coming as i gather parts.
I have that exact kit and believe me that little LEd puts out more than enough light. Find a reputable shop to install them, unless you are really comfortable cutting your own sheet metal.
Old 10-04-2014, 06:24 PM
bigpooma's Avatar
I used 16g steel and led trailer lights.
Old 10-05-2014, 03:10 AM
Originally Posted by bigpooma
I used 16g steel and led trailer lights. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=578524"/>
What size are those lights? I like that look better than the ones I linked. I just think the little lights look out of place next to the big ass 4" one. Oh and what did you have to cut to make yours? Just the raised corners where the original screws go?
Old 10-05-2014, 08:56 AM
bigpooma's Avatar
the reverse lights are 2.5". I found them on ebay. You'll have some cutting to make the new lights fit. I just used a grinder on the raised corners until they were flush. Just use a washer behind the hole when you go to mount the lights on those two locations. You should be able to use the light plate to mark holes for the other bolt locations. The dimensions of the plates are 6"x10".
Old 10-05-2014, 09:01 AM
bigpooma's Avatar
Here's a shot of the plates after hole sawing and painting. For some reason the app freezes my phone when I try to upload more than one pic on a post.
Old 10-05-2014, 05:46 PM
i have that same problem with the app on my phone started when i upgraded to ios 8. i was planning on doing these lights today but my jeep is at my buddies shop getting a new power steering pump woulda been done friday but we broke the pulley swapping it and couldnt find one anywhere, i am going to try to get it done next weekend i think
Quick Reply: led tail lights, something different
