New LED headlights
Old 02-13-2016, 11:40 PM
Alp1n3's Avatar
Well I went ahead and bought some off brand CREE LED headlights off eBay. I must say, these things are super bright! They were purchased on a Tuesday and received on a Saturday. I will say this tho.. The instructions for wiring them were TERRIBLE. They are extremely vague and for someone who doesn't speak "wiring" they won't be able to just plug and play these. In the product description the seller has a photo of the "instructions" on how to wire them. It seems simple. But what I actually received was quite a bit different. In the instructions they provide on eBay it shows one ballast. I recorded two.. With different wiring on each. And the colors they say to use on certain areas are all backwards. Literally. Example would be the navy wire is supposed to go to the accessory fuse and the brown is the ground... They're actually backwards and if you don't know that you'll be scratching your head for quite some time trying to wire them up correctly. But once you figure out how to properly wire them you then have to shave a little plastic off the connector that goes to the OEM headlight connector so that it'll fit snug inside for a solid connection. Despite the few things I mentioned these headlights are sick. Especially for the money. Click image for larger version
ID:	637643 Click image for larger version
ID:	637644 Click image for larger version
Old 02-14-2016, 04:40 AM
xxlt73's Avatar
Looks great and love the grill of the truck
Old 02-14-2016, 05:59 AM
arjeeper's Avatar
What sort of pattern do they throw? The picture said 80w (x2) LEDs.
That's a ton of power for LED headlights. I'd be concerned about temporarily blinding other drivers if they really use that sort of power (there are 50" LED light bars using just 100w).
They do look really cool.
Old 02-14-2016, 06:45 AM
Alp1n3's Avatar
Originally Posted by xxlt73
Looks great and love the grill of the truck Sent from my iPhone using JK-Forum
thank you!! My buddy from home works at a body shop and they dipped it for me and hand painted the dedication on there when I got back home
Old 02-14-2016, 06:51 AM
Alp1n3's Avatar
Originally Posted by arjeeper
What sort of pattern do they throw? The picture said 80w (x2) LEDs. That's a ton of power for LED headlights. I'd be concerned about temporarily blinding other drivers if they really use that sort of power (there are 50" LED light bars using just 100w). They do look really cool.
it looked to be a pretty nice spread pattern. And you're right they're bright, really bright. I'll attach a pic of the spread inside my garage.
Old 02-14-2016, 07:17 AM
Rogue26's Avatar
Those do look nice and you can't beat the price. It shows a turn signal halo how does that look? Bright enough during the day? Is it pretty noticeable at night with the headlights on?
Old 02-14-2016, 09:27 AM
Alp1n3's Avatar
I haven't wired the turn signal in just yet (need to pick up a soldering gun) but the halos themselves are very noticeable
Old 02-15-2016, 12:35 PM
Alp1n3's Avatar
So I just tried to tap into the turn signal... Everything worked fine until I got it out back together.. Put the left turn signal on and both Amber LED's would flash as if I had the hazards on. Any ideas on how to fix this would be greatly appreciated.
Old 02-15-2016, 02:42 PM
pgoty's Avatar
Default Nice!!
Looks bad ass, I just upgraded mine to the Sunpie LED w/o the DRL and I love them. I did buy the trucklite antiflicker harness though.
Old 02-15-2016, 03:05 PM
Alp1n3's Avatar
does it help? And what was the cost?and thanks man!!
Quick Reply: New LED headlights
