Oznium bolt LED marker lights
Finally got these installed after cutting fenders....I think they look as good as factory, then again I'm a little biased. If anyone is scratching their head on which way to go, figured I'd offer some pics for you to decide. Install was a piece of cake with the addition of a small 1/2" hole and splicing the two marker lights wires together. Red = positive Black = ground. Red attached to white marker wire, black to black.
These are are the Oznium bolt LED, amber colored, 11mm flush mount -
On:
Off: (You can hardly tell they're there unless you know where to look)
On:
Feeling a little bit of pain because I cut the fenders awhile back, knowing I'd need to get some markers on there eventually.
Ordered over $100 of those Ozniums in various configs (dome light, superflux red/white, surface-mounts to do gauge cluster), and I totally spaced on getting the amber lights!!!
These particular ones are bright white and not amber, but would still make for a great side marker. They're bright as hell. A lot of people in my Jeep club use these exact ones as rock lights.
eBay has them for cheap. I can't hit eBay here at work or else I'd link you, but for example, here's a 12-pack of these lights from Amazon for $17: Amazon.com: Universal 12pcs High Power White 9w LED Eagle Eye Bumper DRL Fog Light Motorcycle Light Daytime Running DRL Tail Backup Light Car Motor: Automotive
