Power Window Issue
Looking at the wiring diagrams, the window circuits are not controlled by the TIPM, other than getting power through the RUN-ACCESSORY relay and circuit breaker C-1 in the fuse box.
If there is a chip involved, it will be in the switch module in the dash.
There is a switch that cuts out the rear window switches. Have you cut out the rear switches to see how it behaves when you start the engine?
