Switches for Lockers.
You can order it thru mopar but unless you have a rubicon it is worthless. There are rubicon specific wireing harnesses that are required to make it work.
I need the whole panel (pod) as I'm not going to using any of the wiring after I order it. Just the cosmetic part.
I can rip off all wiring and boards that are connected and the rewire all of the switches inside the casing. Swap the "axle lock" switch for a mono, then use the left switch for front axle, right switch for rear.
