AEV Procal VS. Superchips Flashpaq
I know the flashpaq is a engine map reprogrammer and is meant to give a little more power where as the procal is meant to compensate for tires & gears. Now both will do the same things were as the flashpaq remaps, but is the extra cost of the flashpaq worth it vs the procal?
Also, I take your screen name to mean you have a 2013 Wrangler. If so, the Superchips does not work on the 2012-13 models with the 3.6, so it wouldn't work for you anyway.
