AEV Procal VS. Superchips Flashpaq
Old 01-13-2013, 03:27 PM
13-JKU-Freedom's Avatar
Default AEV Procal VS. Superchips Flashpaq
I know the flashpaq is a engine map reprogrammer and is meant to give a little more power where as the procal is meant to compensate for tires & gears. Now both will do the same things were as the flashpaq remaps, but is the extra cost of the flashpaq worth it vs the procal?
Old 01-13-2013, 03:44 PM
JKRVEE's Avatar
Long story short...no
Old 01-13-2013, 05:13 PM
jwilson2598's Avatar
Also, I take your screen name to mean you have a 2013 Wrangler. If so, the Superchips does not work on the 2012-13 models with the 3.6, so it wouldn't work for you anyway.
Old 01-13-2013, 05:55 PM
Ok thanks, Ill just save some money and go with the AEV procal.
Old 01-13-2013, 09:35 PM
JKRVEE's Avatar
You won't regret it
Old 02-16-2013, 03:54 PM
nautique210's Avatar
Originally Posted by JKRVEE
You won't regret it
I have a 2013. Want to run 33" tires with no tpms. I've read you can set the pressure to 0 to avoid the warning light. But someone said it still give a warning when you first start the jeep. Is this true?
Old 02-16-2013, 07:10 PM
eslack32's Avatar
No. It will be off for good.
Quick Reply: AEV Procal VS. Superchips Flashpaq
