Xprite 7" Inch 80W 9600 LED W/ Halo rings
Anybody running these? I'm seriously considering them.
Amazon.com: Xprite 7" Inch Round 80W 9600 Lumens Hi/Lo Beam 15W XT-E Cree LED Headlights With Halo Ring Angel Eyes DRL For Jeep Wrangler JK TJ LJ 1997 - 2015: Automotive
I just bought the ones with the halo rings. Did you use the H4/H13 adapters or plug right into the headlight harness?
Great, Thanks! One more question if you don't mind me asking. Where and how in the fuse box did you connect the red wire for the Halo Ring DRL?
Mine didn't have halo rings, however you should connect them to the park lights as they will act as the park light and then with a procal you can set your Park lights as the drl. Hope that was helpful
Sent from my SM-N920T using JK-Forum
Saw your post and I am planning to buy some LED Head lights also. Seriously considering the Xprites you bought. Three questions:
How do you like them 10 months later?
Did you get flick after install? (if so, I need to get the anti-flicker harness too).
Are they too bright on low beam for incoming driver (flicking their brights at you)?
