JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Differential breather tubes
Old 10-11-2015, 10:33 AM
  #21
LoneWolf's Avatar
I took the DIY route. It was so much cheaper than the River Raider kit, I couldn't justify it.
Doing the diffs was easy, but I couldn't track down the tranny and transfer case breathers to save my life.
I didn't post a write-up on the forum when I did it, but here's what I posted to my blog, with photos:
https://smokeythejeep.wordpress.com/...reather-lines/
Sent via Jeep wave from my NSA-approved domestic-espionage device.
Old 10-11-2015, 12:07 PM
  #22
Tycho's Avatar
Cheap fuel filters make good caps for the end of extended breathers.
Old 11-01-2015, 06:14 PM
  #23
flatattack's Avatar
Originally Posted by LoneWolf
I took the DIY route. It was so much cheaper than the River Raider kit, I couldn't justify it. Doing the diffs was easy, but I couldn't track down the tranny and transfer case breathers to save my life. I didn't post a write-up on the forum when I did it, but here's what I posted to my blog, with photos: https://smokeythejeep.wordpress.com/...reather-lines/ Sent via Jeep wave from my NSA-approved domestic-espionage device.
'12 and newer, the Transfer Case tube should be located on the firewall right behind the engine. The Automatic Transmission tube should be under the plastic engine cover.
Old 06-30-2016, 10:20 AM
  #24
spmitchell86's Avatar
I routed my rear breather into the taillight compartment as well.... Does anyone know if I can leave it facing downward or if it needs to be vertical? Stock location is basically horizontal.
Old 06-30-2016, 04:27 PM
  #25
bob987909's Avatar
Attachment 651115
It doesn't matter if its vertical or not. If you get water that high you have other things to worry about
I would recommend securing it with some grey rtv or something
Old 06-30-2016, 06:11 PM
  #26
I reused the plastic ring from the original location behind fender liner and a trim clip to hold it to a preexisting hole in there.
Old 11-10-2016, 08:57 AM
  #27
WaterRat72's Avatar
Is it 5/16 or 3/8 size tube for replacement?
Old 11-10-2016, 11:09 AM
  #28
14Sport's Avatar
5/16". See link in post #3 above.
Old 11-13-2016, 06:32 PM
  #29
WaterRat72's Avatar
Thank you
Old 12-07-2016, 10:17 AM
  #30
stew's Avatar
Thank you for posting this. Been wanting to reroute my breather tubes since I put my lift kit on.
Quick Reply: Differential breather tubes
