JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Recovery Equip
Old 06-06-2008, 01:29 PM
Beaver's Avatar
Don't waste your time with ARB, ordered kit, waited 6 months, cancelled order, they shipped it after that anyway packed so poorly 1/2 was missing through the crumby box. Poor company !!!
Old 06-06-2008, 03:07 PM
Rubimon's Avatar
Not sure you would have that problem if you ordered it from Dave at Northridge 4x4.
http://www.northridge4x4.com/proddet...G-ARB-RECOVERY
Old 06-07-2008, 09:03 AM
Gokracer1's Avatar
Thats where I plan on picking mine up from
Old 06-07-2008, 11:48 AM
CJK
CJK's Avatar
Originally Posted by derekls
Thanks for the link. I will check into about picking one of those kits up.
Yeah I dont wanna wait but I know ill get stuck a time or two at least lol, since im new, just wanna go prepared to get out lol
the thing that kind of sucks is I dont have lockers or lim slip ........ just 4wdLow and winch lol
You'll be surprised how much the electronic traction control will help - acts like a limited slip only using independent braking to the wheel(s) losing traction. Know your limitations and don't go alone especially on strange trails.
Old 06-07-2008, 12:37 PM
myklt8's Avatar
And don't forget the most important thing...common sense.
You will get stuck because you will do things that common sense tells you not to (that is the fun part)
But use common sense when doing the recovery, you don't want to hurt yourself or anyone else
Old 06-07-2008, 03:09 PM
Sponsoring Vendor
Northridge4x4's Avatar
They were backordered because they found a issue with the die that they use to color the straps. Very proactive IMHO to fix the issue.
ARB is one of the best companies. And the Recovery gear is the best we have seen.
David
Old 06-07-2008, 08:34 PM
Denny2565's Avatar
Originally Posted by Ryno
Dang... I have a couple tow hooks, a 30' recovery strap, a first aid kit, a flashlight, an ice scraper, and a pocket knife. Oh, and some moist towelettes in the glove box.
Wow you spared no expense with the moist towelettes. All I have is a wad of napkins from Hardee's stuffed under the emergency brake handle.
Old 06-09-2008, 07:26 AM
jkkat's Avatar
Ryno,
Please do not be mad or jellous, We believe in going prepaired. Oh and RubyDoo had a cantainer of moist towelettes 3" diameter and 10" long. And after a strange incodient last weekend, She also has 4 valve stems and valve stem install tool.
Old 06-13-2008, 10:10 PM
4rnr's Avatar
Originally Posted by toad
As long as you don't go out alone
X2
My list is to long, but always have some MREs and water.
Old 06-14-2008, 12:06 PM
HookNLadder's Avatar
Originally Posted by WRAITHYJEEP
seems i carry alot
bag to put it all in at the end weights in at 80lbs
10ft of 3/8 grade 8 chain one 6ft section the other 4ft
base plate for hi-lift extreme
"jaw" for hilift extreme
30ft recover strap
15ft double loop strap
6ft tree strap
gloves
5000lb cargo strap
snatch block
remote for winch
bolt cutters double as branch shears
small combat shovel
2 large utility cleavases
4 cleavases that are usually on my jeep rattling for off road
not in bag
shovel spade type 4ft
hi lift jack extreme
Wow Wraith! I think you forgot One thing.....
Just kidding - I carry a lot of that stuff myself - ya never know what your going to need!!
Quick Reply: Recovery Equip
