Maertz's Half Ass Build Thread
#231
thats a good point, and luckily i didnt order it yet, ill have to wait until the fronts under there and see where everything sits before i order.
#232
when I was young I extended a drive shaft. my dad came in and told me that it would not work. it needed to be balanced Well,I ignored him and continued extending the driveshaft. No money so no choice. Anyway as luck would have it it worked great. so my words to you are.
it wont work stop.. (Now go build and think positive)
#235
#236
#237
Well finally sat down and played with the rear shock mounts slightly and figured out ballpark full bump...
storage tub will have to go which i figured.
Another cross member will also have to go by the looks of it. In my mock up it hit as it is and the pinion is not currently rotated correctly as it hitting the tub.. so it will go up more.
When measuring for the shocks I could manage to fit a shock up to about 24" collapsed with a little work. the 22" which is my current plan should work fine. I debated going to the 18" travel as it could fit, but man im not sure i wont run into other issues... I also don't want to be extremely tall...but its a fun thought to entertain as ive only seen one jk online do it so far...
Tomorrow I will be cutting the storage part out and also another cross member.
#239
