Maertz's Half Ass Build Thread
#251
. O,
Oh right, I remember now. you have that 2x6 piece of steel. That should work nicely. I know I need to take some pictures. I have seemed to have lost my drag link nut on the pitman side. Its amazing how its the little stuff that can set you back. I am using my rear axle as a point of reference for the front axle. I had trouble finding a good fixed point so I used the rear hub. Looking good.
#253
thanks man. for my front i measured dead center of my axle and also dead center of the crossmember up front (the round one that hangs down) I then hung a nut from string on the top one and slid the axle to where it needed to be. For the front to back centering i used the body mounts for both front and rear.
#254
I think I missed the point of your text..... either call me or re explain the question. I sent these to you before... but maybe they'll help you?
** stock crossmember in stock location
#255
Thanks man that bottom one is exactly what I needed! Yeah i noticed we were on different pages but i said screw it and worked on some easier shit to pass the time. I will start working on it again tonight. Appreciate the help.
#258
Yeah i was thinking about that last night as itll be hard to tie it into the crossmember behind it as i need it to be removable.. If i go inside the rails ill have to see what to do with the uppers. Its all just tacked at the moment. I really dislike how huge those brackets i had left were also. i may order some new ones.
#259
Now is the right time to check what you have and the clearance with the wheel... much easier than going back and correcting stupid engineering (e.g. me!).
#260
Whenever I get the time.... I'll redo my brackets and make new arms..... my thought was to use the existing mount (as you have there) as a base and build a horizontal one beside it. Should be plenty strong with decent gusseting, I'll keep similar separation, and I'll get all my turning radius back. I think the brackets at the axle will handle the increased angle, but easy enough to rectify if not.
