Under hood on board air for $80
Old 02-06-2011, 10:39 AM
yellow08jk's Avatar
Default Under hood on board air for $80
A while back I bought a cheap MV-50 12 volt air compressor at O'Rilley's for $50 and have been waiting to get a bracket to mount it next to the brake booster. Last week I saw that Sinister Fab Works had a bracket on sale for $25 so I jumped on it. I have used the compressor several times and it works great. I can get all 4 tires from 10 to 30 pounds in a little over 10 minutes. It will be even better now that I always have it with me. I'm leaving the hose connected and have it secured under the hood.
I may get a tank later for quickly inflating toys at the lake and possibly short bursts of air tool use, but I have other things higher on the list right now.
Old 02-07-2011, 05:01 PM
Blendo's Avatar
Looks like exactly what I am setting up this weekend
Did you remove the rubber feet from the compressor and just hard mount it to the mounting plate?
Old 02-07-2011, 05:04 PM
RevyJKU08's Avatar
Great stuff...looks great!
Old 02-07-2011, 05:05 PM
GreenJK07's Avatar
I did the same about a year ago with a slime compressor. Used a hose clamp and Mounted it to the cage in the rear and ran the wires and hard wired to my optima yellow top. Works like a charm and airs in around 10min! Think It cost me about $60. Sweet mod!
Old 02-08-2011, 03:40 AM
yellow08jk's Avatar
Yes, I took off the rubber feet and put rubber grommets in the holes on the compressor.
I also had to flip the rear bracket that the feet are mounted to so it would fit on the Sinister Fab bracket. And I definitely recommend that you mount the compressor to the bracket, then mount the the whole thing in at once. I initially tried to mount the bracket then compressor and had to backtrack.
Good luck!
Old 02-08-2011, 03:47 AM
yellow08jk's Avatar
Originally Posted by ECHO
IS the Pink bike for the commute during the week
I use the bike to stay in drinkin' shape
Old 02-08-2011, 03:58 AM
wvxlt's Avatar
Looks good. Did you use the viair or the ARB bracket?
Old 02-08-2011, 04:36 AM
yellow08jk's Avatar
Default viair/arb
It's the longer one that can be found here http://www.sinisterfabworks.com/shop/item.aspx?itemid=4
Last edited by toad; 02-08-2011 at 07:13 AM. Reason: Please no direct links to non-sponsors
Old 02-08-2011, 04:47 AM
wvxlt's Avatar
Thanks. For that price I may have to give this a shot. Do you just connect the clips when you want to use it and tie them out of the way the rest of the time?
Old 02-08-2011, 04:53 AM
Bobcatmo's Avatar
For that price, I ordered one to use with my slime compressor....can't hurt to try
Quick Reply: Under hood on board air for $80
