Whitch gears?
PS: I'm a man, just in case you didn't figure it out. Just a friendly "ribbing"
As you can see, the name say "Stephane".....so maybe I made a mistake in "witch" because english is not my first language....but I actually know the difference between a man and a woman name.
No, seriously, you should leave it as is with your 33'' tires. 3.73's are perfect. IF you did more off-roading than city driving, then 4.10's would be a bit more appropriate. When you decide to go with 35's, 4.10's would be ideal for mostly city driving, 4.56's would be bringing your RPM's up to about 2400 for highway driving. 4.88's with 35's would be a tad much. Stick with what you got now and if you do decide to go with 35's, 4.10's would be perfect for you. Don't try to over-gear it and have your engine way rev'd up all the time just for the sake of saying that you have taller gears. That's just my 2 cents.
Edit I removed suggestions pending further input.
It is important to make sure you have calibrated your computer with a procal or flashcal. If you don't tell the computer your equipment is different the shift point on your tranny will not be correct and will cause a reduction in fuel economy.
