Whitch gears?
Old 06-26-2015, 09:13 AM
  #31
Stephane87's Avatar
Like Joe said ..... Don't need to make this so complicated !!!! I have an 09 JKU auto I ran 5:13 gears in my Dana 30 on 35's I did eventually blow the gears wheeling. So if you wheel it I'd probably stop at 4:88's tho the 5:13's were nice. I now have a PR44 up front and 37's and the 5:13's still works really well with my set up. If you're staying with 33's I'd save the money and not re gear.
Thanks
Old 06-27-2015, 12:09 AM
  #32
Tooadvanced's Avatar
Originally Posted by Stephane87
Why do you divide by 29? My stock 2010 JKU sport came with 32"...was is already an upgrade that I didn't realize? Because if I do the calculations with 32" as the stock size then a 40" tire would only need something close to 4.66 (gears)....doesn't make sense?!?!?!
I was referring to his math. For you u take your new tire size of 35. Divide by 32 then multiple by stock gear. I have 3.73 stock which means I need just over 410s. I'm going to go 456. Keep in mind also that your stock 3.21 have no business being in a jeep. They are the stupidest gear ever put in a wrangler.
Old 06-27-2015, 04:42 AM
  #33
KVJK08's Avatar
Originally Posted by Wrangler428
I went from 33's and 4.10's to 35's with 5.13's. My mpg is the same and it drives great.
Don't mean to hijack the thread, but I was curious how it was with 35s and 5.13 gears. I want to regear soon. Did you notice much difference, like did the Jeep pick up speed a little faster?
Old 06-27-2015, 10:56 AM
  #34
Stephane87's Avatar
My stock gears are 3.73...
Old 06-27-2015, 09:54 PM
  #35
Albino Lizard's Avatar
Regardless of the stock gear ratio, i'd look at the gear charts for your model. They use transmission gear ratios for your model with corresponding engine rpm's.
Old 06-27-2015, 11:00 PM
  #36
If it was me I would go with 4.56 with 35/37s on a 2012+ jeep if you spend time on road. 4.88 if a lot off road or hill country. If going larger than that tires you have much more to worry about
Old 06-28-2015, 03:59 AM
  #37
robsjeep9's Avatar
^ USELESS!! He drives a 2010 as he CLEARLY wrote in his opening post.
Old 06-28-2015, 04:32 AM
  #38
Former Member
karmynsbeep's Avatar
I wheel my jeep often and live in the foot hills of Appalachia I run 35" bfg km2s with a six speed and 4.10s I love it I don't feel as I need a deeper gear set, and despite all the warnings and naysayers when these 35s are gone it's getting 37s bolted back in their place.
www.overlandoff-road.com
Old 06-28-2015, 04:51 AM
  #39
robsjeep9's Avatar
Another USELESS post as the OP CLEARLY wrote he drives an auto to open this thread
Old 06-28-2015, 04:56 AM
  #40
Former Member
Thanks rob for your useful insight
Quick Reply: Whitch gears?
