Coolant smell!
Coolant smell!
Lately I've had a coolant smell. It's not coming from the vents and you can really only smell it from outside the vehicle. I did notice my reservoir was a little low. I park it in the same spot and there are no puddles. I took the cap off and everything looked fine. I'm stumped and really don't wanna take it to the shop yet. I haven't had any overheating issues at all. Maybe the cap is bad and I didn't catch it?!?! Has anybody had this problem? Or know what it might be?
Could also be a bad head gasket or cracked block or head allowing coolant into the cylinders, then to blow out the exhaust. Often you can tell by the feeling of moistness of the exhaust fumes, or by white (foggy) smoke. How many miles on this Jeep?
Check your water pump. It may not be enough of a leak to leave a puddle, but check for a white crusty buildup around the gasket. These waterpumps are notorious for early failure, and the antifreeze smell is definitely a symptom.
I had this exact problem. It was the water pump. Fixed under lifetime power warranty.
