Loss of Traction?
So I have a 2007 4 door JK X Unlimited. Just put some new 33's on it & all of a sudden I'm having some troubles. When I make a sharp turn my traction light flashes & I can feel the back tires skidding. Someone please explain to me what is wrong?
The steering wheel is straight, the tires r the same brand (Nitto All Terrain Terra Grapplers) just an inch taller & wider, & I don't think it's the brakes because they've never did that before
Did you go to a tire center that did a complimentary "alignment" when the tires were mounted? You steering wheel is juuust a shade out of center. It really is a simple drag link adjustment.
Owners Manual:
Disabling ESP for Modified Vehicles (4WD Models
Only)
Vehicles modified with larger tires and/or suspension
lifts may experience early ESP activations as compared to
a non-modified production vehicle depending on lift
size, tire size, suspension changes and/or driving habits.
If early ESP activations are experienced while driving a
modified vehicle, the additional ability to permanently
turn off ESP is available. A steering wheel/ESP button
maneuver must be performed to permanently disable
ESP and defeat the functionality of the ESP switch.
Repeating the procedure will return the system to normal
ESP operation and restore ESP switch functionality allowing
ESP “Partial” or “Off” modes.
The following procedure will disable (or re-enable) ESP
functionality in the vehicle:
1. Shift the transfer case into the 4H range position.
2. Turn the steering wheel until it is centered and the
wheels are pointed straight ahead.
3. Cycle the ignition key OFF to ON.
4. Wait approximately five seconds for the system bulb
check.
5. Turn and hold the steering wheel one-half turn to the
right (clockwise).
6. Press and hold the ESP OFF button for seven seconds.
7. Turn the steering wheel back to center, and turn and
hold an additional one-half turn to the left (counterclockwise).
8. Press and hold the ESP OFF button for seven seconds.
9. Turn the steering wheel back to center.
10. Press and hold the ESP OFF button for seven seconds.
11. Cycle the ignition key to OFF.
After performing the ESP disable procedure correctly,
“ESP OFF” will be displayed in the odometer for approximately
12 seconds each time the ignition is moved to ON.
Repeating the ESP disable procedure will re-enable normal
ESP operation.
Note: The above is easier with engine running.
As said earlier, steering wheel must be adjusted dead straight.
Edit: I should add this from the owners manual:
WARNING!
With ESP in the permanent disable mode, enhanced
vehicle stability offered by the ESP and ERM systems
is unavailable. In an emergency evasive maneuver,
the ESP and ERM systems will not engage to
assist in maintaining stability. This disabled mode is
intended for off-highway or off-road use only. Vehicle
modifications requiring the owner to configure
the vehicle in the ESP disabled mode, will seriously
affect the vehicle’s roadworthiness and safety and
may lead to loss of control and/or accident resulting
in possible serious or fatal injuries.
Only)
check.
right (clockwise).
ESP operation.
WARNING!
