New Wrangler Rumors
New Wrangler Rumors
So I've been seeing a lot of the rumors about the new Wrangler and specifically the lack of a soft top. I'm looking for opinions on that from folks. I've been a Jeep guy most of my life, and one of the reasons is the soft top. If the new Wrangler doesn't have one, I'm not sure I'll buy another Jeep. But I don't know if maybe I'm being a little crazy on that.
What are your thoughts?
Don't worry, future Wranglers will have a soft top. The design question is how the new integrated sport bar / roll cage works. Think unibody tub but still on a full frame. Will the upper roof rails be flush or recessed? If flush, then cloth can roll / slide like the Liberty Sky Slider. Plastic panels can also fit as on the Renegade. If cage is recessed, then a full cloth and full hardtop works.
Flush structure is cheaper to manufacture and cuts weight. Less wind noise, fewer leaks with internal drip rails.
Recessed structure is more of what we are use to but adds weight. Likely wind noise at header and water leaks but fewer since tub should be stiffer.
I'm definitely looking forward to seeing the new Wrangler. I'll be in the market soon and would like to weight its value against the present era JK.
I loved my '12 JKR so will just pick up a late model JKUR if the '17 doesn't dazzle.
I'm mostly interested in performance. I still have a pipe dream that Jeep will buck the EPA beast off it's sick and offer a 5.7l V8 in the Wrangler. I'd be lined up. But that's a dream.
In reality I'm interested in if they boost the 3.6l power and I assume offer an auto tranny with more gears.
But at any rate, it'll have a soft top.
My thoughts - wait until the thing comes out. Then, go check it out, mull it over, and if it doesn't have a soft top, figure out if your underwear is really bunched up about it. I will say that the lack of a soft top will make the next Jeep feel a little weird, if it's not available with one.
Even if some future Wrangler did stop offering a soft top, there will be aftermarket manufacturers that would step up and sell one.
possibly with a newer fuel map or somthing similar but i dont thing the 3.6 has much more room for any mechanical HP gains unless the up the displacement a bit or compression.
Did they not do away with the 3.6 overseas I thought it was dropped from the line up? Not that they will do that here since we always seems to get very limited drive train options where as the overseas crowd tend to see three to four. From what I read sometime last year there was a test mule that had a slightly stretch front frame that seemed to indicate the added length for the eight speed tranny in FCA's other offerings and think they don't have much choice to help aid in higher mpgs. Also wouldn't be surprised to see a turbo four banger offering along with the diesel but only time will tell.
I didn't know about the Pentastar overseas. Interesting. But you're right, we don't really get the options typical in other markets.
