Snatch block
I have used ARB snatch blocks for a long time, and they have never failed, but Masterpull has a new line of snatch blocks that are designed just for synthetic lines. Check them out, it may be worth the look
Winch Rope, Winch Line, Recovery Rope, Kinetic Recovery Ropes, ATV Winch Lines Ropes, MASTER PULL Recovery Gear
Will the 30,000 lb. rated snatch block work for a JKUR?
One thing people misunderstand about this kind of item is the price. Yes they are expensive, but you are buying something one time. This kind of equipment, even when minimum amount of maintenance is done, will last a lifetime. Hell, some of my recovery equipment is actually decades old rigging gear that was actually used when I was a full time arborist/tree climber in Charlott, NC. All of it still works flawlessly! You are only buying this stuff once in most cases, winch lines get replaced the most, then probably snatch straps (unless you're breaking those doing crazy pulls).
