Stolen tire
#31
FYI for anyone running the PSC tire carrier with plate relocation...a 2" trailer coupler lock with a 1/4" pin can be used as extra security with just a touch of filing with a rat tail file without even removing the spare. As an added bonus, no fumbling with the hex heads behind there to get the bracket off.
#32
Probably somebody already mentioned it, but if you have a wheel lock on your spare all they have to do is tighten the other two nuts, which will make the one with the lock loose.
#33
Yeah someone did. That's why I added the coupler lock. Starting feeling like it wasn't protected like I thought.
#35
That should prevent that method. The rotating sleeves came out because you could pound a socket on it and remove it. So to be effective, you really should do all the lugs, 23 in all.
#36
#38
#40
