Suspension upgrade
Suspension upgrade
I currently have a rough country 4" lift that was on my jeep when I bought it. It has 2" coil spacers in front to "level it out". It's pretty much just coil spring and shocks. Control arms and everything else seems to be factory. I plan on replacing it all tho with better quality stuff. But my question is where should I start? Coil springs, track bars, control arms, shocks, or discos.
I started out with a 3" level kit then upgraded front & rear jks adjustable track bars when I got the bucks. Then saved up some more for metal cloak adjustable control arms with bilstein 5160 shocks.
Oh and if your running a 2 door, I would highly recommend at least a front aftermarket driveshaft if you wheel. Yours will not last long on any lift over 3". Especially a 2 door.
I would start with adj trac bars to re center your axles, then move to control arms to correct the castor and pinion angles. That way you will get the geometry back on track and better steering and ride quality. Then you can move to quick disco's and upgraded or longer shocks depending on the direction you want to take your rig. That way you have the basis to adjust to go bigger if you want in the future without having to overhaul the suspension again. Hope this helps!
