Serpentine Belt / Tension Pulley
Old 07-27-2013, 01:07 PM
mbodella's Avatar
Default Serpentine Belt / Tension Pulley
I cant get the tension pulley back into place, I used a 3/8 rachet and placed it in the square hole and lifting but cant get it back in place, what am I missing?
Old 07-27-2013, 05:20 PM
tribulation138's Avatar
might be stuck. it is spring loaded
Old 07-27-2013, 05:45 PM
mbodella's Avatar
I took the pulley completely off where did the spring go, it must have feel off
Old 07-27-2013, 11:55 PM
TokenMSJ's Avatar
Spring is sealed inside the end that's not the pulley end. Not likely to have fallen out..
There are two square holes in the thing for getting the ratchet in.. Make sure you're using the right hole.. One doesn't fit quite right and you'll slip out of it easily.. Could be that you need some extra leverage to get the pulley up.. When the belt comes off, you COULD have both hands on the wrench and the belt falls off pretty easy.. Putting it back on you almost have to have one hand holding the belt up tight, while you use the other ONE hand to get the tensioner pulled back and then try to slip the belt in place with the third hand..
Old 07-28-2013, 08:27 AM
mbodella's Avatar
Thanks going to try and do this again
Old 07-29-2013, 01:54 PM
mbodella's Avatar
thanks got it, took less than 2 min thanks again
Old 01-24-2015, 10:02 AM
patmasterflash's Avatar
Ok,
So I installed an upgraded alternator and now I have this horrible squeal. I read several threads that suggest this is the water pump, idler pulley, gunked up serpentine belt, or bad bearings.
Here are the specifics:
--My JKU only has 1,100 miles on it.
-- This sound only happens at low speed in first (backing out of a space, pulling out from a stop).
--This ONLY happens when I turn the wheel left or right while moving.
--The sound is not present while sitting at idle.
--The sound is not present while driving 5mph+
Before I figured out how to move the tensioner pulley, I did play with the bolts on all of the pulleys. Could I have tightened one of them too much?
Please help?!
Old 01-29-2015, 05:01 AM
bevan7170's Avatar
If it only happens when you get on the gas it sounds like it's slipping to me. Put more tension on the belt.
Old 01-29-2015, 05:53 AM
mattyk's Avatar
Originally Posted by patmasterflash
Ok, So I installed an upgraded alternator and now I have this horrible squeal. I read several threads that suggest this is the water pump, idler pulley, gunked up serpentine belt, or bad bearings. Here are the specifics: --My JKU only has 1,100 miles on it. -- This sound only happens at low speed in first (backing out of a space, pulling out from a stop). --This ONLY happens when I turn the wheel left or right while moving. --The sound is not present while sitting at idle. --The sound is not present while driving 5mph+ Before I figured out how to move the tensioner pulley, I did play with the bolts on all of the pulleys. Could I have tightened one of them too much? Please help?!
I had this and luckily it was only the idler pulley.
Old 06-10-2016, 07:00 AM
jeep122003's Avatar
Default Tensioner Pulley
Is there supposed to be a little movement with the tensioner pulley? There is no noise at all.
Quick Reply: Serpentine Belt / Tension Pulley
