Stubby Front Bumper
Old 07-25-2014, 04:13 PM
DCT1964's Avatar
Default Stubby Front Bumper
I just finished up this project based on info from another thread, it took me about 5 hours to cut, grind, trim and fit the pieces together then I coated it with a flexible bed liner coating.
ID:	567563Click image for larger version
ID:	567564Click image for larger version
ID:	567566Click image for larger version
ID:	567567Click image for larger version
Next the rear bumper!
Old 07-25-2014, 05:45 PM
Whitejk13's Avatar
Looks great, write up? What ends are those?
Old 07-25-2014, 07:04 PM
DCT1964's Avatar
They are the factory ends, I just cut them down to fit inside the hollow part of the plastic bumper and bolted them in place. It's a cheap build, I have $14.00 in doing this project, $11.00 of it was for the Dupli-Color Bed Armor and the rest was for the screws to bolt it together.
I cut the bumper 2.25 inches from the edge of the bumper bulge then ground it down to a clean strait edge then I cut the ends that were cut off down to about 5 inches in length and trimmed them on a belt sander until they fit inside the main part of the plastic shell. My bumper was pretty faded so I chose to spray it with the bed liner to finish it off.
The tools I used were:
Sawzall (Borrowed from neighbor)
Angle grinder
Drill
Belt sander
80 and 180 grit sand paper
Old 07-26-2014, 02:06 AM
Whitejk13's Avatar
Awesome If I have time this weekend I'm gonna do it also, the spray makes it and I like this so much more than the bulky end caps you buy.
Thanks a lot I'll post it up here if I get it done this weekend
Old 07-26-2014, 02:28 AM
Mountain Man Tim's Avatar
all the stock ends seem to do at stock length is collect mud.... and you spent more then $14! 5 hours of labor, mechanic work, so $20 an hour, $100 dollars in labor going by cheapo rates!
Old 07-26-2014, 05:45 AM
ill1cit's Avatar
Did you trim your fenders or are they aftermarket?
Old 07-26-2014, 08:42 AM
DCT1964's Avatar
The fenders are the Smittybilt XRC Fender Flares.
Old 07-26-2014, 08:43 AM
DCT1964's Avatar
True but the labor I would have had to do even if I bought the after market end-caps.
Old 07-26-2014, 12:35 PM
TheWhiteBread's Avatar
Looks really good!! I have the vdp end caps(only took 20mins) but I would say you probably got more satisfaction by being creative.
Old 07-27-2014, 05:50 PM
DCT1964's Avatar
It's always fun to be creative, the rear bumper I'll have to cut, heat it up and bend the bumper into the shape I want then plastic weld it together but not before I've had several of these
Quick Reply: Stubby Front Bumper
