Walmart Platinum Burner Rock Lights Installation Write-Up & Review
JK-Forum Founder
While we don’t usually make it a habit to purposefully go wheeling at night, there are many times that getting off the trail before dark is inevitable. And, on those occasions, there’s nothing worse than trying to spot a Jeep with it’s headlights blazing in to your eyes. Of course, the driver of the Jeep need to have some kind of illumination to see where they are going so, what do you do? Install a set of rock lights!
Rock lights are essentially small lights that you can mount under your fenders and behind the grill so that they can effectively illuminate the ground immediately in front of your tires but without blinding your spotter. Right now, LED lights seem to be all the rage but, most are either cheap and unreliable or, are way too expensive for my taste. And, even the more expensive ones suffer from putting out way too little useable light. And, that’s why I decided to install a set of Walmart Platinum Burners.
At about $18 a pair, the Platinum Burners are cheap, easy to find just about anywhere, are super simple to install and work surprisingly well. More than any other rock light I have seen, these things put out a really nice spread of very usable clean light. Of course, if one goes bad, replacing it just requires you to located a nearby Walmart. I have been running these on Moby Dick (our white JK) for a little over two years now and have love them. Of course, the write-up below details the installation of a set I put on Nemo.
JK-Forum Founder
if you do that, you need to make sure that each pair is attached to it's own switch or, you want them all to be on the same switch, you need to use a relay and the proper gauge wiring. we did that on moby dick and it works great - will have to do that to nemo sometime too
Looks great, I've been hoping you'd post this!
I can't find the driving lights on walmarts website, I hope they have them in the store when I stop in!
