2 1/2 inch spacers or 2 1/2 coils
Ive always been told you get what you pay for but i need some advise. I only want to go to maybe a 35 inch tire but i dont want to lose to much driving or handling traits from stock. this is my daily driver and it a lift is gonna wander, shimmy or chew up tires i will probably leave it stock. Maybe im just asking for feed back. I even thought about a .75 front spacer kit alone.
Lifting causes issues. The taller you go, the more pronounced those issues are. Adding components corrects those issues. Educate yourself on the problems, and at what heights people start wanting to correct those problems (this will vary due to personal opinion). Then figure out which components correct which issues, and look at each specific lift to see what is included.
As an example - Because you chose lift mfg A instead of lift mfg B isn't the cause of flighty steering/wandering. It happened because you lifted the suspension, the axles tilted, and the caster went down from 4.xx degrees to 3.xx degrees. This happens with any lift from any mfg, and gets worse as the height increases. To fix the issue, you need to raise the caster. To raise the caster, you need some form of caster correction. The options are cam bolts, drop brackets, longer/shorter fixed control arms, adjustable control arms, or put the money into cutting/turning or an aftermarket housing with caster correction. But again, it is not specifically because you chose A instead of B. It is simply because the caster went down. At 2.5", some people don't worry about caster correction. Others don't like the lower caster, and opt to do something about it. Will you care?
Forgot the part about coils vs spacers. A 2.5" spacer should give 2.5". The height given by a 2.5" coil can vary quite a bit, and depends on how each mfg designed their coils, which model of JK you have, how much extra weight you have added, etc, etc. Some people report 2" from their 2.5" coils, generally you should expect about 3", and some mfg's design their coils for jeeps that are fully loaded and fully armored. These can give 4" or more to unarmored, light vehicles. You need to research whichever coil lift you decide on to get an idea of what to expect. Just remember that the taller you go (actual height gained, not what number the mfg puts on the coil), the more components you will want to correct the associated problems.
Mines also a 2015 jkur most everyone ive talked to will say they have no problems with anything i just know how my luck rolls. I really want a lift but not to find out i hate the way it drives. Talked to salesman at mfg And he told me at 2 1/2 inches i would have to either do spacers with stock wheels and tires or aftermarket wheels i dont understand that
Why are you adding a lift? So you can run taller/wider tires, right? To run taller/wider tires, you need to move those tires further out of the wheel wells to keep them from contacting the frame, the control arms, the skid, the ...
To move the tires out, you need to either add spacers/adapters to your current rims, or you need to buy new rims with less backspace/offset.
Stuck right to the top of this modified area is a thread called "My Thoughts On Lifts". It gives some good information, and might be worth a few minutes of your time.
Well actually he told me even running my stock wheel tire combo with a 2 1/2inch coil spring lift would require spacers i also have read almost all of the sticky it is very informative.l told said salesman i would be running stock tires being as it only has 6500 miles by the way thanks for replying
Some lifts (teraflex I think has posted about this?) offer new swaybar links that could possibly interfere with the stock rims. The 'fix' was just to move the link to the inside of the bracket/swaybar instead of outside like the directions call for. But in general, you want to move them out simply because of the larger tires.
Im glad you said teraflex because that is mfg A. Ok that explains alot. I think 2 1/2 of lift with stock wheel/tire may look funny. So if i go with springs/spacers bump stop extensions longer shocks/shock extensions and rear track bar bracket is better than just springs.
