Advice on lift kits and towing
I have a 2014 jk 2 door 6 speed that I'm looking to lift about 3" (I want to be able to run 35's no problem). My jeep is not my only DD but I do drive it on the highway quite often. I do usually use it to tow my boat though. My boat weighs about 1,600-1,800 pounds with a tongue weight of about 200-250 pounds. I don't do the rock crawling or dunes or anything like that, however I do use it in the mud. I'm looking for some advice/input/suggestions on lift kits that would fit what I'm looking for and allow me to still tow my boat with out any problems. Thanks in advance!
Lift kits mean nothing to towing except your steering is going to be light at that lift height. With 35"tires the gearing in your axles is going to be the issue. Running flat fenders and maybe a 3/4" coil spacer would be plenty for 35's with proper wheel back spacing. How did you determine you needed 3" of lift to run 35's?
You are right adding height can reduce stability and handling but has nothing to do with tow rating, just comment sense. Motor, transmission, axle gearing, coil rates, tire rating, and braking capacity are the factors that make up the tow rating. A properly lifted jeep with proper gearing and oversized tires (with proper load rating) can tow better then a stock.
I run a 2.5 teraflex coil lift and 35's 4.10 gears and a manual. I tow a 10ft John boat and get bogged down on big hills. The rear doesn't do the sag but I'm sure if it was something heavier you would notice. I don't mind the small boat and my gears because I don't drive very far but I wouldn't tow anything bigger with those gears and 35's. I still have clearance but I also put everything I need in the boat.
I didn't determine I needed 3" to run 35's. I said about 3" and I want to be able to run 35's without any problems. I definitely don't want to do spacers. I want a complete short arm kit. I've seen trucks and jeeps that have been lifted and when you put a load behind it, the back end squats more than without a lift. I'm just trying to avoid that. I wasn't sure if some lifts had a softer suspension than others. I know gears will be an issue but that's not what I'm asking.
I have a 3.5 in lift with a 3/4 spacer under the front running 37s and a firestone airbag kit in the rear springs. It solved all my issues for trailer tongue weight and road stability. I have 4:10 gears and a bush wackier flat fender kit as well. With a 200lb tongue weight and 70psi in the bags it sits level.
