Sponsored by:
Sponsored by:
building a winch bumper around Olympic's winch plate?
Old 08-25-2016, 06:20 AM
kejtar's Avatar
Default building a winch bumper around Olympic's winch plate?
So I'm pondering what to do about the front bumper for my JK. I found the Olympic winch plate mount which looks like a good solid starting point. Then I can build the rest of the bumper around it. Thoughts?
http://www.extremeterrain.com/olympi...jk-507174.html
Old 08-25-2016, 07:33 AM
westchester's Avatar
I like that the Olympic winch plate sits lower, down inside the frame rails, rather than on top like other winch plates, Ares, Harbor Freight, etc.
I figure you have the skills and a unique front bumper design in mind, so looking forward to watching your build.
Old 08-25-2016, 09:11 AM
kejtar's Avatar
The way it sits kind of sold me on the using it - I want to have it low and not obstruct the radiator. I do have decent fab skills - and figure $100 might be a good shortcut (time/steel/effort) in the build
Old 08-25-2016, 09:16 AM
Chuck-The-Ripper's Avatar
If you have the capabilities of building your own bumper why even waste the money buying the winch plate? That would be the easiest part. Just a piece of 3/8 steel between the frame rails either welded to them or weld "L" brackets to it to bolt to the frame rails.
Old 08-25-2016, 05:28 PM
JRJKUS's Avatar
I like the low,set up. Subbed for future ref
Sent from my iPad using JK-Forum
Old 08-25-2016, 10:05 PM
kejtar's Avatar
convenience/timing I figured that I might do things in two stages - use the plate and install the winch and then build the rest of the bumper as the time allows.... the only fly in the ointment that I discovered is that this plate has no place for mounting the fairlead or hawse which means that I would have to fab something for the front anyways.... so I might take this design and improve upon it and create a semi open box (bottom, right, left, front) that bolts in and allows for the hawse/fairlead. might extend the front a bit to the right and left so that it also bolts where the stock tow attachment points bolt in for the rigidity and weld the sides (right and left) up the edge to the front for further reinforcement. Btw, probably would not go too high on the right and left - about the same as the olympic mount has them (though theirs goes down not up)
Old 08-26-2016, 10:45 AM
kaptkrappy's Avatar
1/4" steel plate bolted through the frame rails.
Name:	Winch Plate 1.jpg
I made this bumper to wrap around it.
Name:	Front Bumper 1.jpg
Installed
Old 08-26-2016, 04:29 PM
kejtar's Avatar
So you went with the 1/4" to avoid the plate flexing under load? I'm hoping that I can stick with 3/8 as long as it's 'boxed'
Old 08-28-2016, 05:25 AM
kaptkrappy's Avatar
When I looked at aftermarket winch plates, almost all of them were 1/4". I had both 3/16" and 1/4" available so I went with the 1/4" straight across the bottom of the frame.
Old 08-28-2016, 02:32 PM
kejtar's Avatar
Hmmm - I was going with 3/16 becaues most bumpers are built out of 3/16"..... for a winch plate that shouldn't make much of a weight difference to go to 1/4" though and it would stiffen up the front.... and I do think I have enough of a 1/4" laying around to make a winch plate/shelf 3/16" I'd have to go shopping for.... ah... the choices..... it's always about the choices
edit: and now that I relooked at the Olympic plate and reread the description on the bottom it states - 1/4" plate I guess that settles it
Quick Reply: building a winch bumper around Olympic's winch plate?
