Can you still drop front control arms with skids installed?
It looks like from the photos that you can't drop the front lower control arm straight down and out if you have skids installed such as the EVO ones. Is this the case or is there enough clearance to drop only the lower one out, or do you have to first remove the upper one in order to pull the lower out?
Thanks!
Thanks!
Mine dropped right out with no problems, don't forget it swings down on an arc. Your front axle might want to shift towards the rear of the Jeep and make it harder than what it is. Use a ratchet strap to assist.
