Do not install Detroit Soft Locker on 2012+ Jeep JK with automatic
#21
Sponsoring Manufacturer
#22
If the shop claims they did a 4 wheeln alignment then you got taken.
Now they put those alignment paddle things on all for wheels regardless of the alignment performed.
#23
I did some checking and found that the new 12 auto trans computer is a bit more complex than previous models. While driving it monitors yaw, pitch, acceleration, vehicle speed, wheel speed etc. A Detroit Locker is always locked until traction on a corner allows the outside tire to unlock. When equal axle speed is achieved after the corner, the unit once again locks. It is suspected that the lock/unlock motion of the locker is tripping the computer. The ProCal is not able to compensate.
#24
There are no adjustments to make on the rear axle....even if you have adjustable rear control arms the only thing your are going to do is adjust pinion angle....but they still does nothing as far as alignment goes.
#26
same issue it sounds like with mine
I have a 2012, in Ft Worth TX, been 3 and a half months without my jeep. Installed Detroit in a D-60 rear!! I have had so many things changed in attempt to fix, AEV, Northridge, Sam Alliance dodge and Baertrax have all been AWESOME in trying to help me but nobody has been able to nail it down. Josh at Baertrax thought after a process of elimination that maybe its the Detroit. We are going to swap out and see, cross my fingers!!!!
What it would do was drive fine but then, it seemed to me, on hard left turns it would "lock up" in limp mode, starting off in 2cd gear only and would hit 3rd but nothing more, would not let you manually shift either. Would have to shut off completely to "reset". Like I said been dealing with this for almost 4 months now, have made 3 payments and put about 30 miles on it.
My new concern is another thread I read on here about the exact same issues, and its happening without having a detroit installed and no regearing so now I'm worried that Im installing a new ARB and that its not the issue????
HELP - Anyone please---------Steve
#27
a4x4guy- Please send me a link to where you have seen the issue with limp mode without a gear swap or Detroit.
#28
For me after reading some issues and taking the Internet with a grain of salt I decided that it was not worth potentially having an issue and having to pull new lockers and pay for installs twice. I'm paying to ship back my grizzly lockers ( Dave at northridge is allowing me to return them) and have the yukon zips installed at an additional $1k :(
For what it's worth I have not found any threads from anyone who has a 12or13 with front and rear auto lockers with an auto trans that was positive, again on the flip side I have only found 3 threads with complaints.
The reason I asked about alignments earlier is because I have heard that with it off it can make the auto lockers act up and I figured that could cause the new computer to have a fit.
Steve
#29
#30
On the bright side, I get to test out the f/r truetrac combo on the exact same trails as the locker/trutrac combo I had in the past. Excited to see how well this set up runs. I believe the truetrac lsd front and rear working with the factory bld will hold its own. Running some steep rutted hills at Butcher Jones OHV near Phoenix AZ in the morning.
