Front Axle Options
Front Axle Options
I have been investigating/researching the possibility of purchasing upgrading my front axle on my 2013 Jeep JKU. I had been looking at the Dynatrac Prorock 44 Unlimited and then I came across another option through Fusion 4x4.
A lot of folks on here are at least familiar with Dynatrac, so here is the info I received from Fusion 4x4. They do state their opinions on some things.:
There is a lot of marketing out there and many a fan base built on limited knowledge. The PR44, in a box, is a really nice axle. However, it is a $5200 D44. That part, I struggle look past. It is certainly not the magic that people perceive it to be. What you have vs. a standard D44 is a stronger housing. That is it - a stronger housing for $5200. If you are running 35" or larger tires, you are still running parts that aren't designed to run a tire that large. Weak unit bearings, small ball joints, small brakes, small steering, etc. Yes, you can upgrade the brakes and steering, but now you have over $6k into a D44. My point is that when you really step back and think about what you get, it just isn't that much. If the PR44 were $3k, totally different story. I'm a guy who has run a D30, a built 44, blew up a D44, etc. I've done it all, sold them all, and learned a lot along the way. I have a habit of tracking failure data that comes up on or off the forum. I see the parts that fail and the ones that don't.
A front Rubicon axle can be picked up cheap these days. Some gussets and a truss and all is well. If someone can break that, it's D60 time. If you are looking seriously at axles like this and considering a 60, that tells me you are someone who plans to use it.
Now, one thing I like to mention is the JK rear D44. Most underrated axle ever. It is a strong axle. If we are talking semi-float axles, I would run a rear JK44 before I ran a semi float PR60. With a PR60 semi float, you will still bend flanges and wear bearings out. Is the larger ring gear stronger? Until someone provides me with definitive data, I do not believe it is. The PR60 is high pinion, which means it runs on the weak side of the gear. Deflection occurs under load. The JK rear 44 is low pinion and runs a larger thick cut ring gear and near D60 size pinion. The tubes are large. Really, it is a great axle for running 37s. 40s are questionable only because people will spec 5.38 gears, which results in less tooth contact. If a person could run a 4.56, it would likely hold up to moderate abuse.
That is background to my view that the JK world has it backwards. It should be 60 front, 44 rear. With a 60 front, you get all the big parts you need, plus all the benefits of locking hubs. Now, when I say 60 front, 44 rear, I am talking about the 99-04 D60, which is not the monster that the 05+ is. It is 69", not a pig in terms of weight, etc. It is a really nice balance.
How we would recommend someone do it is to run the 60 front in a 5x5.5 bolt pattern and in the rear, run adapters that go from 5x5 to 5x5.5. Inexpensive and it brings the rear in line with the width of the front. Yes, you have to get new wheels, but it is a nominal cost after selling your current wheels.
We use front unit bearings that are plug and play with the JK ABS sensors. Pricing really depends on what options you want. Some people want it all up front, some are fine running some stock components and upgrading later. Simply stated, we can sell you a front D60 for less than the PR44 you have priced out.
Below is my current set up along with the Dynatrac PR44 and Fusion4x4 D60 set ups I would be considering. With the exception of requiring a new front drive shaft the Fusion4x4 set up would be about $500 cheaper which I believe would cover the cost of a new front drive shaft.
My current set up:
- 2013 JKU (4dr)
- Rock Krawler 2.5 Max Travel lift
- Synergy front track bar
- Synergy sector shaft brace
- Fox steering stabilizer with the synergy relocation kit
- The front track bar is in the factory location
- Factory brakes
- Factory knuckles
- Factory tie rod and drag link
- Factory front drive shaft
When I have been looking at the Dyntrac Prorock 44 Unlimited, I have priced out the following:
- Dynatrac ProRock 44 Unlimited housing
- Re-use/retain stock knuckles
- Set up to connect to factory front drive shaft for now
- Re-use/retain stock brakes
- Set up for factory track bar location
- Re-use/retain Synergy front trac bar
- Re-use/retain factory drag link
- Re-use/retail Synergy sector shaft brace
- Re-use/retain Fox steering stabilizer. New axle would have new mount.
- Either Synergy or Dyntrac ball joints
- 4:56 gears
- Either Eaton E-Locker or ARB Locker
- RCV axle shafts
With the Fusion 4x4 set up, they would be building:
- Front axle as mentioned above
- Re-use/retain Synergy front trac bar. New axle would have bracket with height options.
- New axle would come with new larger brakes
- New axle would come with new knuckles
- New axle would come with new tie rod and drag link. "Stock" (came with larger axle) stuff or have option to upgrade.
- Front drive shaft will have to be replaced.
- 4:56 gears
- Eaton e-locker
- New axle would come with new ball joints to fit.
- "Stock" axle shafts are 30 spline outer and 35 spline inner
Honestly I am learning as I go here. I am not overly experienced or educated on all of the parts and process. So with the info above and below, what are your thoughts, opinions, recommendations, etc.
My current set up:
- 2013 JKU (4dr)
- Factory brakes
- Factory knuckles
- 4:56 gears
- RCV axle shafts
- 4:56 gears
- Eaton e-locker
It's not even a question. I go through unit bearings almost every month. Ball joints last maybe a year if I'm lucky. Prorock retains both of those. The fusion axles were created by actual jeepers for jeepers to give a better option compared to the Prorock. An analogy comparing the two would be: buying a new Camaro and deciding between the v8 or the v6 model IF they were the same price. (Hypothetically obviously). Why not have bigger, better, and stronger for the same price? Even if you think the prorock would fit your current needs, wouldn't it be nice to have no doubt that your axle is strong enough to run nearly any tire you would throw at it?
I know the Fusion axles would be stronger. I guess the fact that upgrading parts, or having to work on or replace parts later would involve looking for items that aren't even Jeep parts (both either stock or upgrades). Thus my lack of knowledge plays in to fuel the hesitation or fear. But I guess you've got to learn somehow, right?
What are folks thoughts on manual locking hubs? I know a lot of hardcore off-roaders like them. I just have always liked not having to exit the vehicle to go into 4wd.
What are pros/cons to going manual locking hubs?
I can take a picture of the receipt when I get home. I should still have it. I just replaced the unit bearing in this video, no joke, less than 2 weeks ago. I just uploaded it so you can see.
I daily drive roughly 100 miles a day to Pittsburgh and wheel pretty hard almost every weekend or every other weekend. I just replaced the ball joints a couple weeks ago with the teraflex so I hope to have success with them as the last ones I've replaced it with were autozone brand. I think I went through 2-3 sets of them since I've owned the jeep. Do you have rcvs? I've heard people say they contribute to the longevity of the hubs but I'm not sure if that is factual or not.
https://youtu.be/6IvpfVbVcc8
OP, as for your question regarding parts to be replaced in the future, which probably won't happen often: You could have them list each part specifically as in which exact vehicle or such it comes from. I don't think anyone over there would mind giving you a complete parts breakdown. I'm sure they probably do it anyway.
Its a pain coming from always on, but you have the option to leave them locked also...
** edit ** correction, I see Dan put it in his email....not on the site itself **
Although most everyone likes the beefier is better, good to know that the 99-04's give a good balance.
