Has anyone built there own lift kit?
1 Post
Has anyone built there own lift kit. As in not buy a kit but all the parts separately from the brands of your choice? If so was it difficult and do you recommend just getting the kit?
I have Rock Krawler triple rate coils 2.5" up front 3.5" in back. Bilstien shocks, Tera Flex control arms and Tera Flex front adjustable track bar and TF rear track bar bracket. I mix and match parts. they work well together.
Ended up with poly Springs, metalcloak arms, Tera flex tracbars, Fox resi shocks. And some other miscellaneous brackets.
Work very well and I plan on doing something similar with my 2nd jeep I just got.
It's a lot easier to just buy a kit. You'll drive yourself nuts piecing it all together, second guessing each and every decision on each and every part. And after the 6 months you spend on that, you will smack yourself in the forehead when it sinks in that you could have been driving a lifted jeep all along if you had just bought a kit...
But yeah, many of us have pieced lifts together. Just make sure you do the research so you have an idea if there are any fitment issues between mfgs. (mostly this comes up with steering components and sometimes trackbars and coils, or trackbars and diff covers.)
Evo front coils 4"
MC rears coils 3.5" ( for level stance)
Teraflex front lower arms
Teraflex rear uppers and Synergy rear lowers
Synergy drag link flip
JKS front track bar
Super lift rear track bar
I'm all over the map. But it's what works and rides well for my 4" lift
Former Vendor
No issues doing the mix and match. That said, you are likely to get a better deal buying a kit. Some other benefits of a kit are if you have any issues such as ride or handling or something else. If you have RK coils, TF control arms, Rancho shocks, JKS track bars, etc., who do you call? If it is all RK for example, you can call and it is easy for them to help diagnose and resolve an issue. A company will ensure their kit works as advertised. It is difficult to help when it is a franken-lift.
We also believe that there is value in the consistency of design. Same style bushings everywhere provides consistent movement. Manufacturers tend to know the best combo of shocks to their coils, etc.
Don't get us wrong, we love custom suspension. However, we know the time and effort that we have put in to making them work the way we want them to vs. buying a kit that worked out of the box. We piece together when things get more complicated, such as long arms or different geometry. However, we are still consistent with the parts we use in a single design.
I bought my wife's jeep with a zone lift and I've steadily replaced parts as I went. I wish I could've convinced her just to have a good shop install a quality lift from the beginning.
Front-TeraFlex LCA's
Bilsteins all around
Rough country discos
Rough country adjustable track bar( Don't buy, flexes way too much)
Kept Zone coils, added a lift puck to front because of bumper sag.
Mine is a mix of Metal Cloak, Old Man Emu, Synergy, PSC, Poison Spyder, Letz Roll Off Road, Rubicon Express, local driveshaft shop and my favorite local Jeep shop.
I could not afford an entire "kit" all at once, so, shopped around for the bits and pieces I though would work best for their designed purpose as funds allowed.
In hindsight, even if I could have funded an entire kit, I believe I have a better build having thought it out for myself.
One more note, it was nice that Metal Cloak started applying the OME shocks to their kits... made that decision much easier.
