How to safely remove fender flares?
I'm buying a 2014 billet silver rubicon today. It has the paint matched hardtop but the black fender flares. I want to remove the fender flares to color match paint them. What's the best way to remove them as to not damage them? I've seen guys just rip them off to instal flatties, but that must tear apart the plastic holes?
It doesn't really. I took painted fenders off my Sahara and bought some unpainted ones off craigslist to cut and put back on. Once you are sure all the bolts are removed in front, you can literally just rip them off with no ill effects.
FWIW, I ended up selling my painted fenders for $200. The unpainted I bought for $100. So I netted $100 on my fender trim
EDIT: Just re-read your post... I am not sure that the black unpainted ones are able to be paint-matched as they have a texture to them, whereas the paint-matched fenders are smooth.
Might as well get a bunch of the new clips. No matter how careful you are, you WILL break a few of them. X2 on double checking how your fenders will work getting painted with texture finish.
As far as the textured fenders? Not easy. But a few nice coats of epoxy primer, like three part DuPont Euro-Prime, will easily fill the texture and make a very smooth durable surface for base coat clear coat. DO NOT TRY TO SAND THEM FIRST. you will cause furry little rips(gouges) in the plastic and make it even harder to get a smooth surface for paint. Just clean them really well with soap and water, then prep them with a pre paint solvent prior to primer coat. Then wet sand lightly with 320 sand paper until the surface is perfect.
This is the same procedures for use on all other grainy plastics on Jeeps. Or any car.
Fender removal will be fine. It will sound much worse than it actually is. Invest in more plastic clips, but otherwise the stock flares are infact pretty durable.
