Sponsored by:
Sponsored by:
Good idea for rims? OR save money!
Old 03-09-2013, 04:17 PM
UsnRoberts's Avatar
Default Good idea for rims? OR save money!
Soooo Im thinking of running the pintlers for the wk/xk on my JKU with 285's. Is this a good idea?
I have been reading and I don't know what im reading.... Basically
Old 03-09-2013, 04:56 PM
SpicedCrusher's Avatar
What are you asking?? Whether you should buy new wheels or not?
Old 03-09-2013, 05:00 PM
kh202's Avatar
Yeah I'm kinda confused too.
Old 03-09-2013, 05:23 PM
jadmt's Avatar
different lug pattern if you are asking what I think you are asking.
Old 03-09-2013, 05:29 PM
UsnRoberts's Avatar
Basically, I liked the price here but I don't understand offset and everytime I begin to understand it, I get confused again. I guess what I am trying to say is.. Are the wheels below a solid choice on a JK or should I keep saving towards the JK version of the pintler?
WK/XK Pintler Non-Beadlock Wheels - Wheels - Shop By Category
Old 03-09-2013, 05:40 PM
UsnRoberts's Avatar
I have figured it out.
Basically. Stock backspacing is 6.25"
These have a backspacing of 5.75"
And the JK pintlers have 5.2"
So basically this will push the wheel out of the fender half an inch. I don't if that is justifiable for even buying new rims even though I'm not going to wide 35's
Last edited by UsnRoberts; 03-09-2013 at 05:40 PM. Reason: red squiggly lines everywhere
Old 03-09-2013, 05:41 PM
nthinuf's Avatar
You were too fast with that post...
Yep, check the pattern first. Could be 5x4.5 instead of the 5x5 you need.
Also, all of the factory wheels have a higher backspace, which keeps the tires back inside the wheel well. As you move to taller and/or wider tires, you need to start thinking about moving them out. (lower backspace number)
For the money, aftermarket wheels are probably the better choice.
Old 03-09-2013, 06:38 PM
jadmt's Avatar
those won't work on a 07-13 jk/jku
Old 03-09-2013, 06:45 PM
kh202's Avatar
Why not? The backspacing isn't ideal (4.5" or less is best) but these should indeed fit a JK....they say 5x5
Old 03-09-2013, 07:14 PM
jadmt's Avatar
I guess a person could/should contact AEV and see if they will work. If it is only the backspacing that is different on the pintlers then it should not really pose a problem if using near stock sized tires. Best bet would be to call AEV and find out for sure. If they would work and a person is not going to end up with much larger then stock tires they would be a good deal. it is possible that the hub on a commander is a different size then the jk not sure on that. the jk has a 71.5 mm hub so not sure what size the commanders are.
Quick Reply: Good idea for rims? OR save money!
