Play in D44 shafts?
Play in D44 shafts?
Hey guys,
Picked up a Rubi takeoff D44 yesterday, and upon closer inspection today, I noticed there's some in and out play in the axle shafts. About 1/8 to 1/4 inch. Is this something to be worried about? Or will it go away once I install rotors? Here's a quick video of it: https://youtu.be/rl_-t0jTNB8
Much obliged.
Brian
Much obliged.
Brian
Speaking of newbness, anybody know of any good axle swap writeups? This is the only one I've found, but it focuses more on wiring than anything else: Y90's Rubicon Axle Swap Write Up
If they are loose, they either loosened on their own, or were loosened by someone.
In either case, you should remove them and install new nuts.
The amount of play you detected certainly called for further investigation. A small amount of play is normal, though. Not that they all have some play, but a lot of them do.
For some reason my rear rubicon shafts have about 1/16 or 1/8 outward play. All my bolts are torqued down properly. Friends rubicon has the same issue as well... Not sure if it's supposed to be that way or what. Maybe yes because of the locker?
I'd prefer to shim them to minimize the looseness, but they seem to be doing well as is. They're not failing all over the place.
