rear shock install, what direction? (fox 2.0)
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Mar 2012
    Location
    APO, AP
    Posts
    136
    Default rear shock install, what direction? (fox 2.0)
    Does it matter what direction the rear shocks go in? i.e. gas tube on bottom with shaft pointing upwards? Or gas tube on top with shaft pointing downwards?
  2. #2
    Join Date
    Mar 2012
    Location
    APO, AP
    Posts
    136
    vs
    seems like they can go either way, and fox install sheet doesn't mention anything about it.
    Any pros and cons of either way?
  3. #3
    JK Freak JLsJK's Avatar
    Join Date
    Nov 2011
    Location
    Sevierville, TN
    Posts
    802
    I inverted the rear shocks on mine, with the shock body on top. Seems to me the body is less likely to be hit and damaged.
  4. #4
    Join Date
    Mar 2012
    Location
    APO, AP
    Posts
    136
    Has anyone taken a bump to it? Just wanted to see what other people are running
  5. #5
    Join Date
    Nov 2011
    Location
    timberwood park, tx
    Posts
    265
    Always thought nitrogen charged shocks had to be mounted body side up?
  6. #6
    JK Jedi rinkishJK's Avatar
    Join Date
    Jul 2009
    Location
    NORTH JERSEY
    Posts
    4,038
    The body goes up.
    2009 Silver Rubicon Unlimited 6 Speed
    #26403
  7. #7
    JK Enthusiast DanieltheManual's Avatar
    Join Date
    Apr 2011
    Location
    BC Canada
    Posts
    456
    Bar pin up.....? Is there another way....
    2011 SPECIAL OPS:
  8. #8
    EzK
    EzK is offline
    JK Super Freak EzK's Avatar
    Join Date
    Oct 2010
    Location
    MD
    Posts
    1,350
    I'd mount them up for clearance and protection. Isn't the bar pin on the body end anyway?
    2008 RRC Rubicon Unlimited
    -2.5" RK w/ Bilstein 5100
    -PSC Evap skid
    -Rancho Oil Pan Skid
    -D44 Riddler Covers f/r
    -Sway bar motor flip
  9. #9
    JK Enthusiast suds1485's Avatar
    Join Date
    Oct 2011
    Location
    new york
    Posts
    224
    I'm not sure but the should only go one way. At least that's what I thought. I haven't installed aftermarket shocks yet just extensions. The reason I say one way is because the mounts are different unless the bracket piece just slides through one of the holes. Or the manufacture makes them specific to the vehicle.
  10. #10
    JK Freak Jp3792's Avatar
    Join Date
    Oct 2012
    Location
    Gp
    Posts
    801
    The rubber housing should be down this allows for it hit the rubber harder and save the shock, it also allows the shock to be protected from rocks and debris flying off your tires or when you are out
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
