Sponsored by:
Sponsored by:
Gobi Rack and AEV Corner Guards
Old 10-23-2012, 01:37 PM
Fox3's Avatar
Default Gobi Rack and AEV Corner Guards
Anyone with this setup:
1. Would it be easy to bolt the Gobi towers to the AEV Corners Guards?
2. Could you foresee this causing future problems, by having the Gobi towers attached to the frame AND the body/corner guards?
Old 10-23-2012, 04:36 PM
skibovr6's Avatar
The gobi rack came with two little steel pieces that mimic the corner guards. I wouldnt use plastic corner guards but metal would be fine.
Old 10-23-2012, 06:57 PM
ShakyJake's Avatar
I've had my Gobi mounted wit Bushwacker plastic corners for 2 years without any issues. In fact, the guards have offered some scratch protection, even with the provided plates. I can only imagine the AEV corners being better.
Old 10-28-2012, 06:16 AM
Fox3's Avatar
Thanks skibovr and shakey.
Will probably try the AEV corners and Gobi, but bolt the rack into the corner panels
Old 10-28-2012, 06:17 AM
Fox3's Avatar
.....actually, NOT bolt the rack into the corner panels
Quick Reply: Gobi Rack and AEV Corner Guards
