Rock krawler lift upgrade
I have a 2014 jk polar edition on 35s with a 2.5" flex system Rock krawler lift.
JK 2.5 Flex System
I have rancho 9000xl shocks
RS999330 (rear) 2.5"
RS999329 (front) 3"
I want to add the rest of the control arms
Front upper adjustable control arms
Rear upper adjustable control arms
Rear lower high clearance adjustable control arms
I was also thinking of upgrading the springs from 2.5" to 3.5".
With the following info would I be able to add the springs or will I need to upgrade the shocks?
JK 2.5 Flex System
RS999329 (front) 3"
Former Vendor
If you go to the 3.5 you may want to consider a front driveshaft. Going to high steer down the road on a 2 door is a nice option as well, but all of those items can be done as budget allows...
Good luck with your continued build...
RK
RK
