Sleeved and gussetted D30 strong enough to rock crawl with 37" tires?
#21
RING GEAR etc. INFO
You MAY be OK if you are careful. Many are....and then again, many are not. Driving/wheeling habits WILL be a factor in how your setup will hold up. As stated the D30 diff will be your weak link. Here are some specs for your consideration:
............................................Ring Gear / Splines / Axle Dia / Pinion Dia.
D30 JK (non Rubi front)..................7.2"...........27 ......1.16".........1.38"
D44 JK (non Rubi rear)...................8.5"...........30 ......1.31"
D44 JK Rubicon (rear)....................8.8"...........32......1 .41".........1.63"
D44 JK Rubicon (front)...................8.5"...........30......1 .31".........1.63"
D50...........................................9.0"
D60..........................................9.75" ...........35......1.50"
D80.........................................11.25"
KG6SLC aka Eugene
KG6SLC aka Eugene
