Sponsored by:
Sponsored by:
Sloppy steering after EVO long arm lift
Old 04-15-2015, 04:10 AM
Spudcannons's Avatar
Default Sloppy steering after EVO long arm lift
I just had an EVO long arm lift installed with a FOX ATS steering stabilizer with 35" x12.5" nitto trail grapplers on 17" atx slabs (about 100 pounds each) and my steering is a bit sloppy, a little play before turning when wheel is at center and when going from right to left or left to right. Anyone had a similar issue or have any idea of a solution?
Old 04-15-2015, 05:31 AM
JE8154's Avatar
Did you get an alignment done after the install? Lift height?
Old 04-15-2015, 06:48 AM
Invest2m4's Avatar
Agree, sounds like a legit alignment is a good first step. Additionally, checking all the bolt torques.
Heavy and large tires will also highlight weaknesses in the steering. Worn ball joints, flex in the steering box (steering brace made a world of difference for me), worn drag link ends, etc.
4" lift, alignment and balance wheels/tires. May be the tire pressure, it's at only 26 psi right now I was thinking to bring it up to 32 psi
Old 04-15-2015, 06:52 AM
Monte417's Avatar
Did you flip your draglink and raise your tracbar? At that lift height it's almost a requirement
Old 04-15-2015, 07:16 AM
kjeeper10's Avatar
Sounds like a caster issue. I 2nd alignment.
Old 04-15-2015, 08:08 AM
Both. what PSI are you running or recommend with 35" tires?
Old 04-15-2015, 08:29 AM
JE8154's Avatar
I would start at 28 and drop is as needed but if you're at 26 I doubt that's the issue.
Old 04-15-2015, 08:39 AM
I'm thinking steering box stablizer since the alignment was professionally done by an offroad shop.
Old 04-15-2015, 10:13 AM
Sponsoring Vendor
Northridge4x4's Avatar
If you flipped the Drag link and installed the long arm kit you should have everything you need for it to drive perfectly. I have this kit on my Jeep and can drive with one finger at 80MPH with out any wandering at all.
David
Quick Reply: Sloppy steering after EVO long arm lift
