Sponsored by:
Sponsored by:
Whats normal rpms @70 mph?
Old 01-26-2013, 06:13 AM
A7x2706's Avatar
Default Whats normal rpms @70 mph?
Im runnin 35s on a 2.5 inch lift on my 2010 jku sport so i assume it has the 3.73s. It was a 1 owner so i doubt they regeared and didnt tell the dealer when it was traded. I dont run a procal yet but i know everyone says their setup and stock gears suck. I dont really think its that bad and ill be purchasing a procal today but i was just seein what the normal rpms for these gears are @ 70 mine were right at 2600 with od off.
Old 01-26-2013, 06:29 AM
Blatant's Avatar
I have a '12 JKU, manual tranny, 3.73s and 35s. I'm about 2k (maybe 2,100) in sixth at 70 mph.
Old 01-26-2013, 06:37 AM
OscarTheJeep's Avatar
Sounds like stock gearing to me.
Old 01-26-2013, 06:55 AM
A7x2706's Avatar
I guess im tryin to figure out if im runnin normal or high. Like i said im not unhappy with how it drives, clearly its take off speed sucks ass but its a jeep.
Old 01-26-2013, 07:31 AM
MiJKguy's Avatar
Default help
I got a 3 inch lift with 35's should I be driving with the OD off or on?????
Old 01-26-2013, 07:42 AM
A7x2706's Avatar
Od should be off so you dont search for gears all the time
Old 01-26-2013, 07:51 AM
MiJKguy's Avatar
Default ah I see
thank you! I have been driving with it on all this time , what should be the the rpm when doing 70mpr on highway?
Old 01-26-2013, 08:02 AM
A7x2706's Avatar
I woukd assume if you have the 3.73s like me it will be somewhere around 2600 without a procal with one it would be a little better i woukd assume
Old 01-26-2013, 08:08 AM
MiJKguy's Avatar
cool thanks that sounds about right
Old 01-26-2013, 08:18 AM
jadmt's Avatar
actually driving with od on or off should be determined by terrain, speed etc. If it is in od and not hunting or lugging you will be fine. why run at 2600-2800 rpms driving down a flat interstate at 75 when you will be fine at 2200rpm etc. let your vehicle tell you what it needs.
Quick Reply: Whats normal rpms @70 mph?
