Sponsored by:
Sponsored by:
Wheel spacers
Old 03-25-2017, 04:55 AM
blackie27's Avatar
Default Wheel spacers
So I'm in the market for some wheel spacers. I have a 2017 JKU Sport S. it comes with 32in tires. Would like to put some spacers on them now that I could also use later when I put on some 35s and a lift. I understand they come in different widths. Any recommendations on sizing and brands?
Old 03-25-2017, 05:00 AM
DJ1
Former Member
DJ1's Avatar
1.5" Spydertrax
Old 03-25-2017, 05:13 AM
TheDirtman's Avatar
You would be better off getting new wider with a 4.5" back spaced wheels when you are ready for 35's as the stock wheel is more narrow then most tire manufacturers recommend for the bigger wider tires. Depending on the wheels you choose it may be very little in additional cost.
Old 03-25-2017, 05:20 AM
blackie27's Avatar
What exactly do you mean about a 4.5in back spacer? Is that different from wheel spacers? Sorry some of this stuff is new to me!
Old 03-25-2017, 05:21 AM
DJ1
Former Member
DJ1's Avatar
^ this is the better option....
Old 03-25-2017, 05:23 AM
jedg's Avatar
Wheel Backspacing is the measurement from the hub mounting surface to the back edge of the wheel. This does a good job of explaining it.
Wheel Offset and Backspace - How Do They Relate? | The Squealing Tire
Old 03-25-2017, 05:31 AM
blackie27's Avatar
So would it be safe to say that the back spacing is something included in the rim to where it mounts? Thus giving it a wider wheel base due to the rim without having to mount another piece like a spacer?
Old 03-25-2017, 05:36 AM
jedg's Avatar
Yup.. less backspacing moves the centerline of the wheel outward.
Old 03-25-2017, 05:37 AM
blackie27's Avatar
Thanks! Is the consensus that a 4.5in backspacing on wranglers do the job then?
Old 03-25-2017, 06:05 AM
lowendrider's Avatar
Yes, wheels with around 4.5in backspacing or a quality 1.5in wheel spacer if you want to retain the factory wheels. Spidertrax is well known and respected...thats what I went with.
Quick Reply: Wheel spacers
