Part out
Part out
I have parts for sale.
Pro rock 60's front and rear. 5.13 gears, ARB, 35 Spline, 8x6.5", warn hubs, stub hubs, 68.5 WMS Set up fro front 3 link rear double triangulated 4 link or 3 link and out board coil overs. Roughly 10,000 miles on them. $9500
1.5" wheel adapter for said axles (1 set)
King 2.0 16" travel coil over triple rate $800 for the pair.
King 2.0 14" travel coil over dual rate with compression adjusters. $800 for the pair.
JKS Track bar (series 3) $100
Poison spider HD cross member $100
2.72 transfer case $500
1310 driveshafts (qty 2) 30.5" long $200 each
Ruff Stuff Heim joints for control arms (qty 6) $30 each
Johnny joints for control arms (Qty 2) $30 each
Metal Cloak Joints for control arms (QTY 2) $30 each
17" Moab wheels (4) with worn factory BFG tires free.
I can assist with the axle swap and whatever brackets you want/need for your set up. I will consider trades of factory axles (no dana 30's with 3.21 or3.73), firearms, silver (1 oz sized spot price). Just let me know what you have and the worst I can do is say no.
All Items can be picked up in Reno/Lake Tahoe. I do have a forklift to load axles into truck.
Former Vendor
Wow it sounds like you had quite the build. If you are getting rid of Dynatracs what are you putting in their place? #HS4x4 wants to know.
Former Vendor
Are you running 44s? I run 40s on a PR80/PR60 in my JKU but I run 12" 2.5s with bypass. I had 14s but the ride height was a little high. With that much shock you must be running big rubber.
