True-Trac with 35's
Old 08-23-2010, 03:49 PM
Fly-Attack's Avatar
Default True-Trac with 35's
Anyone running Detroit True-Trac's with 35" or larger tires?
Eaton recommends 32" tires Maximum.
Old 08-23-2010, 04:17 PM
jeepoholic's Avatar
I have Lock Right by Richmond in the rear with 5.13 gear and 35's. I really like the set up you just have to get past the clicking and clacking you hear when you turn.
Old 08-23-2010, 04:24 PM
Bacon's Avatar
the True Trac is a limited slip is it not? the bigger/heavier the tire, the less effective limited slips are. the friction material is usually not up to the task of handling big heavy tires. i'd stick with a smaller tire or wait for a full-on locker., lunchbox or selectable
no, I have no personal experience, just second-hand knowledge, so you can take my advice with a grain of salt.
Old 08-23-2010, 04:36 PM
azxr's Avatar
I put one in my Titan's D44 several months back after my OEM E-locker grenaded. The Titan has 33s. I know there are a lot of Titan owners with them in and they are running 35s. I haven't heard of any issues.
Old 08-23-2010, 06:41 PM
Stoneaxe's Avatar
Well... I just had the Truetrac put in my rear axle. 5:13's and GoodYear 315/70r17 (measuring 33.5 inches loaded). Only had it for a week. I'll be off next week at the beach and some trails to test it out. I'm confident it will work fine.
I don't believe the Truetrac uses friction components so I don't see where they would be adversely effected by tire weight/size.
Old 08-23-2010, 07:13 PM
river2c's Avatar
The 32" tire limitation for the Detroit Truetrac is old product information. I have them in both axles with 35" tires and they work flawlessly. They are a very strong unit and you don't have to worry about tire size. I have put them to the test off road and I highly recommend them.
Old 08-23-2010, 07:16 PM
river2c's Avatar
The Detroit Truetracs are worm gear driven and have no clutches to wear out. They are a very effective traction aiding device.
Old 08-24-2010, 07:38 AM
Sponsoring Manufacturer
Dynatrac's Avatar
As others have mentioned, Truetracs are a helical gear LSD. IMO, it is the ONLY LSD you'd want in a rig that sees off road time because it doesn't have clutches to wear out (clutches will wear quickly when you lift a tire and spin it) . I've sold many of these units over the years and customers have been very happy with them as long as they don't expect them to be a locker. The additional traction they provide over stock diffs is amazing.
The 32" tire warranty is old info. IIRC it is now 38".
Old 08-24-2010, 07:54 AM
Fly-Attack's Avatar
Thanks for the info guys, i think i'll go this route.
Old 07-22-2011, 03:49 PM
Dynatrac's Avatar
Originally Posted by Jollydodger
Do YOU think they will work effectively with 38". I am sold on the idea of the Truetracs but wasn't sure if they would actually do there job with tires that big.
They'll work fine but which axle do you have? I hope you're not trying to make this work on a D30.
Quick Reply: True-Trac with 35's
