latches for tube doors???
Old 03-03-2011, 07:26 AM
robin's Avatar
Default latches for tube doors???
does anybody know where to get latches for tube doors?? it would be great to find something like the ones RANCHO uses, I've been looking all over the place and I can't find them, any help would be apreciated !! thanks.
Old 03-03-2011, 11:46 AM
Rubi up 07's Avatar
You try calling Quadratec? They don't list everything online. Plus they can email you pics
Old 03-03-2011, 12:04 PM
Cunnart's Avatar
could you buy replacement latches for a tj and older type jeep? Quadratec and 4wd warehouse sell replacement parts maybe that would work?
Old 03-06-2011, 06:40 PM
yellow08jk's Avatar
Default Bestop sells the same ones
Google "bestop door latches" and you'll have several to choose from
Kind of expensive though. I thought about them when I built my 1/2 doors but went a different route.
Good luck,
Jim
Old 03-07-2011, 05:31 PM
JK-Ford's Avatar
Have you thought about making a trip to your local junk yard?
Old 03-10-2011, 08:53 AM
robin's Avatar
thanks for the answers, I bought a set of latches from an old vw rabit and they work pretty good, they are similar to the ones used in hot rods, the advantage is that i can get them locally for less than 5 bucks each, and since I'm going to be selling the tube doors its a big advantage. thank you.
Old 03-10-2011, 08:55 AM
robin's Avatar
this would not work at all, we tend to think that rancho uses and old tj handle, but is not true the tj's latches and handles are huge and expensive.
Old 03-11-2011, 08:55 PM
Toposurvey's Avatar
I found a small latch online. easy to mount. The only problem is they are intended for a much larger striker, but i just made a quick shim out of plastic tubing, it has to be replaced a few times a summer, but works fine and i didn't have to remove the existing stock striker. It's not pretty, but works. I'll take some pictures of the final product when i get the chance, (The doors have been through a few iterations sense these photos were taken).
ID:	136608   Click image for larger version
ID:	136609   Click image for larger version
ID:	136610   Click image for larger version
Quick Reply: latches for tube doors???
