Lift kit with 35" tires, how low can I go?
Old 06-27-2011, 11:30 AM
prelucir's Avatar
Default Lift kit with 35" tires, how low can I go?
I am thinking I would like to keep my center of gravity on the low side. I would like to figure out what the lowest lift is that I can put on my Jeep.
Can I put on a 2.5" lift and sucessfully use 35" tires or do I need to bump up to a four inch lift kit?
If I can put on a 2.5 inch lift kit, will I lose articulation buy hitting my fenders with the tires frequently on bumps and such?
Thank you
John
Old 06-27-2011, 11:33 AM
SilverJK12's Avatar
Thank you
John
2.5 you can clear. I did a 4 inch so my depart and approach angles are better.
Someone will have to chime in on the flex though.
Old 06-27-2011, 11:58 AM
Merlin4979's Avatar
I have a Teraflex Leveling Kit and Xenon flat fenders. At the moment, I have 33.5" tires, but as you can see from the pic, there is plenty of room for when I make the jump to 35's.
Old 06-27-2011, 12:31 PM
prelucir's Avatar
Wow, I did not know I could clear 35 inch tires without a lift. I am thinking to continue with the 2.5 in lift however, between the tires and lift that should give my center a four inch raise to clear mounds and prevent high center.
I figure, no matter how high I go with the lift, it will not lift the pumpkins.
I am happy to know that I two and half inch lift will work fine.
I would like to replace my stock fender with flat painted metal fenders, thus providing more travel room.
Thanks,
John
Old 06-27-2011, 12:32 PM
prelucir's Avatar
Karl,
What brand is your front bumper?
-John
Old 06-27-2011, 12:46 PM
FresnoJK's Avatar
Here is mine. 35's, 4 door Rubicon coils and shocks. No lift. Trimmed fenders and chopped pinched seam. I also cut the rock rails by 1.25 inches off the rear (not pictured)
Old 06-27-2011, 12:54 PM
mumbling1's Avatar
I'm about to go 2" with BFG KM2 35's. For grins... I slapped one on yesterday to see if it would fit without the lift. Fits fine except at full turn it rubs the front bumper. Didn't try in the back but I would imagine the pinch seam would be a little too close for comfort.
I took a pic
Old 06-27-2011, 01:06 PM
mataylor1's Avatar
i run teraflex leveling kit, flat flares, and 35/12.50r17. no rubbing,
Old 06-27-2011, 01:47 PM
A2thaK's Avatar
I have the TF 2.5" lift and am running 35 mtrs. At full stuff when disco'd I will rub the fenders. Also rubbed the Rubi rock rail at full flex so I trimmed it back and also trimmed the rock rail. I plan on trimming my fenders too, but as stated I only rubbed at full flex.
Old 06-27-2011, 02:06 PM
Battlefrog's Avatar
Default TF 2.5" BB with 18/59 stock coils and 35x12.50 KM2's
ID:	176146Click image for larger version
ID:	176147Click image for larger version
ID:	176148Click image for larger version
Quick Reply: Lift kit with 35" tires, how low can I go?
