How easy is it to replace the starter on an 08 JK??
Old 10-16-2011, 08:32 AM
Fitba101's Avatar
Default How easy is it to replace the starter on an 08 JK??
Hey guys, the repair shop wants $320 to replace the starter on my 08 jk unlimited. That sounds like a rip to me. I've never replaced a starter before, but im willing to give it a shot. Anyone know how easy it is. Pics/ info is much appreciated.
Old 10-16-2011, 08:37 AM
08YELLO-RUBI's Avatar
Maybe I'm wrong but isn't it covered under the warranty?
Old 10-16-2011, 09:40 AM
Fitba101's Avatar
It would be covered. but i'm past the 36000 mile warranty that came with it, and it's not covered in the powertrain warranty
Old 10-16-2011, 09:51 AM
ZMagic97's Avatar
I don't think it would be bad. I haven't taken it out, but there's a decent amount of room under there. Compared to my 79 Camaro, should be a cake job.
Also, are you sure it's the starter and not a bad battery or relay? Just figured I'd throw it out there.
Old 10-16-2011, 12:39 PM
Fitba101's Avatar
Pretty sure it's not the battery, since I just stuck a new optima yellow top in it about 2 weeks ago. I guess it could be the relay, but I was told the starter was more likely the culprit.
How would you check to see if it was the relay though?
Old 10-16-2011, 12:49 PM
ZMagic97's Avatar
When you try and start it, if you hear a rapid clicking and the starter does nothing, then it's either a relay or battery. Could always try and jump it from another vehicle in case you got a bad battery (not likely, but possible). New relay shouldn't be much either. Also, you could check the connections first, make sure it's just not loose, rusty, or dirty.
Old 10-16-2011, 12:52 PM
OH9JK's Avatar
You have an automatic right? Check the neutral safety switch. See if you can start the jeep in neutral rather than park.
Old 10-21-2011, 09:36 AM
Fitba101's Avatar
Thanks for the help guys!
Old 10-21-2011, 11:36 AM
ZMagic97's Avatar
So, was it the starter?
Old 11-02-2011, 07:24 PM
Fitba101's Avatar
Nope. It ended up being the neutral safety switch as you mentioned. Thanks a lot for the help man, you saved me a few hundred bucks.
Quick Reply: How easy is it to replace the starter on an 08 JK??
